Which way to go?
Which way to go?
i can't decide what i want to do to my truck...was hoping for some input here. first, here's what i have...
1997 F150 XL SuperCab shortbox
2wd/4.6 2V/5-speed, 3.08 open rear end
i have two ideas of what i'd like to do to it...both ideas involve repainting and re-doing the interior so i'm not mentioning that...
idea #1:
lift it with Fabtech's 7.5" lift kit, run around a 35" tire, regear to 4.56 or 4.88s, lock the rear end, winch bumper on the front with winch, auxillary lighting all over truck, mild engine modifications...basically treat it as if it's a 4wd...maybe eventually do a SAS and make it a 4wd...
idea #2:
lower it to just a hair lower than a stock Lightning, regear to around 4.10, maybe 4.56, lock the rear end, run possibly a stock L wheel or some nice 18's with a wide tire to make it handle, modify the suspension to help firm it up-handling being a number one priority, more extensive engine modifications...basically make it a decently quick sport truck...
so...ideas? what do y'all think i should do...i have a clean slate to work with, just not sure which way to go...
edit-sorry the pic is so big...lol
idea #1:
idea #2:
idea #1:
idea #2:
idea #1:
idea #2:
I would say that you should buy a procharger and put some sweet wheels on it! Definitely get some 4:10s! Maybe put a rear sway bar with some lightning leafs, and some bilsteins up front. If I were to ever re-do my truck then thats what I would do to it. The procharger is going to take up a decent chunk of the change, but not when you compare it to the lift, wheels, tires, regearing and all of that. Lifted trucks are awesome, and I love mine but I am a speedwhore too so I get torn sometimes. My truck would be soooo much quicker with the procharger and my 4:56s on some nice 18s and some street tires
IMO, you should save your money and not go for a total transformation. If I assume correctly, yours probably has some miles on it being it's a '97, and things will start needing replaced. Have you checked the front end bushings? I would do all necessary boring maintenance first, then opt for extras if you really want to do it. But to each their own.
thejake1989-the budget is "little at the time" on both directions. i don't have mass amounts of money to throw in it all at once but i will have money to throw in little at the time...
carpenterltd-you're right...171k on the beast. and yep, it does need front end bushings...but that's about it. i will just slowly repair things as they wear out on it (previous owner put a lot into it...it's really pretty solid)
thanks for the input guys, i really appreciate it!
Wow, im in your same deal. I dont really know what to do either. I got a SingleCab 4.6 Shortbed, its currently lowered. I love the sporty feel, I can take corners with more ease and I think it drives very nice. Before I had this truck I had a lifted F-150 and driving that every once in awhile makes me want to go back to lifted. Basically lift and throw a nice tire on there and drive it like that. I dont know which way I want to go either haha. Good luck though.
I'd probably lower it, I've had two lifted 2wds and did it mostly for looks. Or maybe sell it and buy a 4x4 and lift it if you like offroading..really depends on personal preferences
