Power Adjustable Pedals?
hey just wonderin if anyone has ever tried putting power adjustable pedals in a 2000 f150? it's a lariat 4x4 ext cab and i would like toput in power adj. pedals just not sure if i can? anyone know??
Should be able to install complete assembly without an issue because it was an option.
The movable assembly includes the brake switches and anything related to cruise control, the gas pedal and maybe a different throttle cable.
Just look the donor over and take everything related including the dash switch assembly.
IMHO, it's not something I would spend the effort on unless a midget is going to be driving the truck.
Good luck.
Good luck.
Funny Bluegrass
I use my adjustables so my 5'7" midget body can be just a little farther away from the steering wheel/airbag
Hello, I am attempting to do the same modification. I would like to know, if you had to use the throttle cable from the donor truck, or were you able to use your trucks throttle cable? If you used your own throttle cable, how did you disconect it from the original gas pedal?
While you're at it, instead of wiring up some generic switch, get the correct cluster surround form a donor or the dealer. It will make the install look a lot cleaner. (Mine also has the slider, but you can get it with just the pedals):
