Truck Computer Parameters
Old Aug 6, 2010 | 03:12 AM
Stephen87's Avatar
Can anyone tell me all of the parameters that are monitored on these trucks on the computer, namly through the OBD II slot
IE rpms mpg etc....
Old Aug 6, 2010 | 09:39 AM
ONELOWF's Avatar
Lotta stuff. Are you looking at a specific problem?
Old Aug 6, 2010 | 01:44 PM
Stephen87's Avatar
its not a problem I am looking for its just that when I put a computer and a turbo in my truck I want to be able to monitor my fuel pressure, my exhaust gas temp, among some other things(actually as many as possible, I know I will have to install a sensor for a boost gauge but I will worry about that later
Old Aug 6, 2010 | 01:52 PM
ONELOWF's Avatar
Gotcha.
Surf on over to sctflash. com and download the latest version of Livelink 6 (?). It is free. You can play with it, enter your pcm code and see some of the parameters.
Fuel pressure, egt and boost will all require individual gauges for constant on board monitoring.
Old Aug 6, 2010 | 06:06 PM
Stephen87's Avatar
well I went to the site and tried to find it but I couldn't find I guess I will have to try again later
Edit:Found it, also where do I find my pcm code
Old Aug 6, 2010 | 06:57 PM
Stephen87's Avatar
well its not working so I guess I will have to find another copy
Old Aug 6, 2010 | 11:33 PM
ONELOWF's Avatar
The pcm code is on a sticker on the pcm. Look under the glove box, down low.
You can use mine to try the software......FOU1.
Old Aug 7, 2010 | 12:22 AM
Klitch's Avatar
with a 97, a 4.6 and 4r70w yours might be imp4 like mine. But reading your sig you have a manual trans.
You may have to pull the kick panel out of the way to read it better.
Old Aug 7, 2010 | 04:29 AM
Stephen87's Avatar
ok I got it to work but it is late now so I guess I will mess with it tomorrow before I go to work
Old Aug 7, 2010 | 12:58 PM
Bluegrass's Avatar
Specifically, on 97 to 03, there is no monitors for fuel pressure or exhaust gas temp.
On these motors there was never a need to do so.
On fuel pressure, other systems react on a secondary basis to excessively high or low fuel pressure by setting other codes that react/reflect the same.
This involves the table shifting control as the way the whole system monitors on a secondary basis.
These 2 pipe fuel systems use a high pressure pump system that is regulated down to about 40 psi and return the unused volume back to the tank so no need for a monitor.
On later single pipe fuel systems, there is a pressure monitor.
The software will not have a means for doing any monitoring of these two parameters, in stock form, unless lines of program have been included, that a programmer/ tuner can activate.
The programs do have a number of abilities built ino the software as extra but only activated per the model, year and specific build.
As an example, on a larger gas motor model used in an application such as a bucket truck, needs a high idle ability to run the hydraulic pump. This becomes an activated function in the software version and is accessed by an external control of some sort, per the application.
Old Aug 7, 2010 | 03:15 PM
Stephen87's Avatar
I couldnt see any numbers on the ECU but I did see a number on the door it was VIA3 would that be the number I am looking for
Old Aug 8, 2010 | 02:07 AM
Bluegrass's Avatar
Sounds like the PCM version, ok.
