Helllp
Helllp
Hey guys, I have my 2002 F150 Screw FX4, and both front wheels have a small amount of play. This caused the rotors to unevenly wear, which caused my brake pads to be ****. So I know I need to get the rotors resurfaced and I have brake pads to replace the bad ones. Now for the wheel bearings. What is the deal with those? Can I just buy the bearings and replace them?, or do I have to buy an assembly, what do I do? I have never dealt with them before, so cut me some slack. Thanks fellas
-Brandon
-Brandon
Simple, Yes. Cheap, No. Both went at the same time? Talk about crap luck! Good luck man.
-Matt
-Matt
Thanks bro, I found the wheel bearing and hub assembly at my local autozone (Duralast) for $138.99 a piece. So adding those two together, the idler pulley that is fixing to go out, the resurfacing of my front brake rotors, all of it comes out to be around $300. I already have new brake pads to put on. I'll give an update and let you guys know when I do the wheel bearings. I'm gonna do the idler pulley today most likely. Thanks for all the help
-Brandon
-Brandon
