engine cuts out
Right , it has a Fuel Tank Pressure sensor on top of the tank between the pump and the rear vent.
Test pressure and regulator. If it's on the low side, replace filter and check again.
Pressure is always first, - OP needs at least a Chilton's manual- or a Haynes. As it stands, he doesn't have a clue.
Final verdict: crank position sensor. The sensor was on tight but was not connected properly. As I suspected it was related to the compressor repacement job. Glad to have her back on the road. Thanks for all the input along the way.
