2000 F150 2wd Tires
Old Jun 10, 2010 | 03:43 PM
dcaseyb's Avatar
2000 F150 2wd Tires
What are the largest tires I can put on a stock F150 2WD that currently has 235/70-16 tires on it?
I will eventualyy add larger wheels, etc. But for now I just want to put the largest tires I can on the stock rims without leveling kits, etc.
Thanks!
Old Jun 10, 2010 | 04:06 PM
Alex_4.2L's Avatar
probably 285/75/16 without anything like a leveling kit for the front or body lift you might have a little rubbing though. I have 265/75/16s on my truck 2004 heritage(OBS) with no rubbing but it does make it more sluggish. tires look like perfect size for the truck tho
Old Jun 11, 2010 | 10:36 AM
trailhunterf150's Avatar
x2^^^^^
if you go any bigger than 285/75/16 you will need to trim back your valance at the very least. Unless you get a 1.5" leveling kit than you could run a little bit bigger tire without triming.
