rust oleum truck bed coating
Has anyone ever used this? I want to do the bottom of my expy with it. What's better to use the roll on or the spray can type? What do you do to prep the surface, it says to use 120-220 grit sandpaper. Is that ok. thanks, Clint
I use a scraper, then wire brush for dirt and rust! Brake part cleaner for oil and grease! Spray can is faster plus it gets into all the corners and edges! I started on my frame so far it look alot better!
