ball joint questions
Old May 10, 2010 | 03:00 PM
rydin4life's Avatar
I have 160,000 miles on stock ball joints and it's about time to replace both uppers and lowers. I have access to a 12 ton press. My question is, can I buy just the ball joint for the upper control arm or do I have to buy the entire upper control arm assembly? So far I haven't seen anyone that sells just the ball joint unless you have a Moog control arm. Thanks
Old May 10, 2010 | 03:04 PM
westtnfx4's Avatar
Yes you can buy them without the control arms. Also get the ones that have a grease fitting also for longer lasting service.
Old May 10, 2010 | 03:55 PM
Cody4x4tx's Avatar
did ball joints on my truck abt 2yrs ago. why do you want to buy them seperatley? i found it cheaper to get them pressed in with new moog arms for the uppers...the lowers i ordered just the ball joints.
i spent around 600-650 on parts/labor that included an alignment.
check out rockauto.com for parts
Old May 10, 2010 | 04:24 PM
MmmBuckles's Avatar
$600-650??? i only spent about $300 a couple years ago when i bought all the parts. All moog parts too.
Old May 10, 2010 | 04:36 PM
rydin4life's Avatar
I'm going to be doing the labor myself so I'm only paying for parts
Old May 15, 2010 | 11:48 AM
HighLife's Avatar
Just did my ball joints, tie rods, tie rod ends, idler arm, pitman arm... and all those parts cost me $550. That was for the joints with new arms, too so yea.
Old May 15, 2010 | 01:01 PM
wandell's Avatar
I've never seen just a seperate ball joint for the uppers. It's sold as an assembly with the upper control arm.
Old May 19, 2010 | 11:40 AM
fatscew's Avatar
i havent been long replaced all of mine. i had to buy the top control arms and all. the bottom was a severe pain to get out and in. i spent about 220 on all 4 ball joints and the top control arms.
