Slow Speed Overheat
Old May 2, 2010 | 08:43 PM
nick.schrandt's Avatar
Slow Speed Overheat
My truck seems to have a slow speed overheating problem. Today it ran at 208 on the highway which is normal for my truck. Today when driving through town my cylinder head temperature hit 232 which is really odd after it had been running good all day. The question is when I shut the truck off I could not squeeze the top radiator line like I usually can. Does this mean my thermostat is stuck shut?
Old May 3, 2010 | 01:59 PM
formuladriver01's Avatar
I would start cheap first. New thermostat, then look at a new clutch for the fan, then I would look at the water pump. The reason around town driving is hotter is because not as much air is going through the radiator. At a stop light there is no air at all except for what the fan and clutch are pulling through the radiator and shroud. Hope this helps!
Old May 3, 2010 | 02:43 PM
Red02FX4's Avatar
I agree with clutch fan but I would think if the thermostat were stuck closed you would have a major overheating problem. I would start with the fan and go from there
Old May 3, 2010 | 03:15 PM
EsoxShep's Avatar
How many miles on the truck? I replaced a water pump on one with 200K, and the impellor vanes were near worn off! Same issue. Low speed overheating, and fine on the highway.
Old May 3, 2010 | 05:18 PM
rednutbow's Avatar
I just pulled my mechanical fan off my truck if you want one. Im not sure how much they go for though.
Old May 4, 2010 | 04:04 AM
miles 383,000
water pump is brand new
the problem is the fan clutch isnt kicking in at all i can hold it with a hammer and the cht hits 218 and the fan never kicks in.
send me a pm about the mechanical fan
