which rearend?
SiCkO lol
J/K
Check the tag on the rear differential, theres a metal tag with numbers like 9.75 3ls55 which would be the 9.75" and Limited slip 3.55. Or the tag could read 8.8 3LS55 or 3LS75 depending on what you have.
J/K
12 bolts its a 9.75
Yea it will depending on the brake set-up. They all interchange, but if you dont have 4 wheel disks you have to upgrade brake boosters and all that mess to run a 4 wheel disk set-up. If your rear end is howling then I would check the fluid level, but its most likely a bearing going
out.
Oh, and the 9.75 uses a shorter driveshaft than the 8.8 does because the housing of the 9.75 is larger.
out.
Might want to try adding fluids
If its a 4x4, As long as the gear ratio is the same. So youll have to find a 9.75" with 3.55. If yours isnt LS, I'm not sure if you can use a 9.75" 3.55 LS? And Youll need the shorter drive line.
Nvrmind, its a 2wd. 9.75" 3.55 or 3.75 and the shorter drive line will work.
