problem rear end
Old Apr 24, 2010 | 01:21 PM
garysf-150's Avatar
problem rear end
will a 03 9.75 3.55 factory lock ,work in my 99 f-150 4x4
Old Apr 24, 2010 | 01:56 PM
4x4wolf's Avatar
Whats your gear in the front axle?
Old Apr 24, 2010 | 10:28 PM
garysf-150's Avatar
the front is 3.55 do you think my rims will fit
Old Apr 24, 2010 | 10:56 PM
Dnasty777's Avatar
Yes the rims will fit. Just make sure you get the correct lug nuts.
Old Apr 24, 2010 | 11:07 PM
garysf-150's Avatar
thank you
Old Apr 24, 2010 | 11:14 PM
04heritagef150's Avatar
Will a 9.75" rear end bolt right up if you had an 8.8"? I'd been thinking about doing this too
Old Apr 24, 2010 | 11:40 PM
4x4wolf's Avatar
I believe the driveshafts are different sizes but I could be wrong
Old Apr 25, 2010 | 01:32 AM
Klitch's Avatar
the snout/pinion section of the 9.75 is larger/longer, rumor I've read is 1 1/4" needs taken off the driveline.
