Oil Change......UUUUUUGH!!!!!
Old Apr 9, 2010 | 11:07 AM
  #31
Tumba's Avatar
Originally Posted by campo141
Just got finished. Am I the only person who can't stand this task on this truck? The filter always gives me hell. Does anyone have any quick tips for next time? Never mind. Next time, someone else will do it....lol
You're putting your filter on to tight Hand tight is all you need to do.
Old Apr 9, 2010 | 11:13 AM
  #32
ChrisT's Avatar
I always change my own oil on all of my vehicles. I don't mind and it's not a hassle for me, especially now that I'm all grownz up and have a climate controlled garage.
Originally Posted by AZ Mr. Bill
2. Cover oil filter with a Zip-Loc bag (other non leaking plastic bags will work in a pinch).
That is a great idea, thanks! My DD is a 96' Toyota Avalon with a 3.0. That oil filter has to be in the worst possible location, as far as limiting oil spillage. I'll definitely be using this trick next time.
Old Apr 9, 2010 | 11:25 AM
  #33
offroadn'98's Avatar
Originally Posted by Dream150
You just need the right tool to remove the oil filter. I prefer the oil filter cap that goes on the end of a wrench.
Hands down!!! The best tool to use for a filter that's being a PITA is Oil Filter Pliers!!! If the filter's being a trick, i swear that's the best tool!
Old Apr 9, 2010 | 06:07 PM
  #34
campo141's Avatar
Yhays all I do is hand tight. It's justa pita trying to get my damn hands and wrist around the steering controls to turn the damn thing...LOL
Old Apr 9, 2010 | 09:14 PM
  #35
jbrew's Avatar
Originally Posted by ucfperspicere
That, and the big secret is to turn your tire to clear the steering components out of the way. I forget which way to turn (I think right), but this precludes the use of ramps if you can't get under the truck without raising it. My floor jack makes quick work, though.
I don't like to let anyone touch my truck - even just an oil change - without me watching. And I especially hate the high-pressure sales tactics at the dealers.
There it is! I was waiting for that. Yep, you turn the wheels for better access. That gives you a fumble free window if you do it just right.
Old Apr 10, 2010 | 12:58 AM
  #36
doug435's Avatar
my 97 is above the cross member and its a pain to get out its like trying to squeeze a 500lb person thru a midget door ...
Old Apr 10, 2010 | 02:08 AM
  #37
fordf150farmer's Avatar
my 97 filter is on the block (4.6) i just slide under and take out the plug, and leave the wheels straigh forward, and slide up past the control arm and stick my oil filter strap wrench up there and break it loose and pull it out by hand... let it drain and stick the new one in and put about half a turn with the wrench after finger tight just to make sure (once had a bad experience) and then put the plug back in and dump in the new.... start and check for leaks, and off i go! lol
Old Apr 10, 2010 | 07:19 AM
  #38
jbrew's Avatar
4x4's are a little different lol.
_________________
Seems like it would be easier on those PITA 2wd's with the new stubby MC filters...? No ? - Has to be.
Old Apr 10, 2010 | 06:57 PM
  #39
Truckin_98's Avatar
So I am sitting here reading this thread, laughing my butt off thinking about how with the 2 F-150's and 2 Expy's I have owned, it has never ever been a challenge changing the oil and filter. Until today... Apparently I have always had the wheel turned just right to where the filter always cleared, until today. I made a mess, got oil everywhere and had a hard time turning the wheel to get clearance, because I couldnt start the engine, no oil in it yet. Thanks, jerks!!!!
Old Apr 10, 2010 | 07:05 PM
  #40
Chris123NT's Avatar
you're welcome
Old Apr 10, 2010 | 08:06 PM
  #41
campo141's Avatar
Been there, done that!!!
30lbs of kitty litter later, and you can barely tell!
  #42
Toyz's Avatar
At 3.19 a qt for castrol 5/20 and $8 for a MC filter... Under $28 to do it myself and its $45 with a coupon at the shop... 10 changes a year saves me $170 a year doing it myself. And autozone recycles all the oil and filters. I have a 5 gallon drum I put all my oils in.. from my bikes, cars and trucks. When its full, I take it in there and dump it.
Old Apr 10, 2010 | 08:18 PM
  #43
mcolford's Avatar
X2. My local auto parts store recycles it for me too. I prefer changing my own just for peace of mind knowing its done right, and not with air tools. Had a buddy take his truck to one of those qwik-e-lubes and they stripped the threads in his oil pan by putting the plug back in with an impact. Stupid ****s.
-Matt
Old Apr 10, 2010 | 09:28 PM
  #44
Tumba's Avatar
Get a bag of morter from the lumber yard. It will pull all the stains up from concrete.
Old Apr 12, 2010 | 10:49 PM
  #45
jbrew's Avatar
You can use the neighbors cat to sop up the heavy stuff, - then their kitty litter for the rest. - Since they will no longer be needing it.
