more problems
Old Feb 19, 2010 | 10:55 PM
Underdog96U's Avatar
more problems
okay, so a little background,
truck has been in my family since we bought it, its now has 121,572 miles on it. it was a good running truck with nothing wrong with it until i drove it from texas to north carolina. on the way up here, i got the cel, and my heater core went out. this was back in september, when i got up her, i did a basic tune up on her,
new plugs
new fuel filter
new air filter
oil change
i replaced the DPFE sensor
and PCV valve.
i had one coild go bad, go a used one put on it (number 3, went because it was supersoaked in coolant) a week later it another went out. so i replaced them all the week after christmas, well this weekend i developed another miss fire, i got my codes read at the school, and i have a cylinder 7 miss fire, i want pull the cop and check resistance on it to see if that is the cause of the miss. (don't have a scanner with me to do the move and see if the miss moves)
also what else should i check to eliminate a electrical problem causing the miss, and what should i check to eliminate other problems to hopefully figure out whats wrong with my truck.
Old Feb 20, 2010 | 03:57 AM
And what is the truck? What cops did you buy? What brand are the plugs, PCV valve, and DPFE sensor?
Old Feb 20, 2010 | 09:45 AM
the truck is an 01 f-150 5.4l screw
and all the parts i have bought for the truck have been OEM parts.
Old Feb 21, 2010 | 03:55 AM
OEM as in Motorcraft-branded? Those cops must have cost you a small fortune. Did you use dielectric grease in the boots?
