shocks-rears, how to?
Old Feb 12, 2010 | 07:47 PM
brotherhoodv's Avatar
HOLY CRAP!! I thought mine were bad but jeeze! when i took mine out they took FOREVER to spring back up and when compressing the old ones all the way down one busted open. It was 13 yrs old with over 200,000 miles on it
I've only had the truck a year, but I fully believe those shocks had all 173,000 miles on them!
Old Feb 15, 2010 | 10:47 PM
NappyNick's Avatar
A ratcheting box wrench (18mm I think) through the hole provided was the way I found easiest. A deep socket just didn't allow for a lot of room to work with.
Old Feb 19, 2010 | 11:08 AM
fordracing200's Avatar
The whole shock body turns as one, rusted solid so I cut the fronts out on top with a reciprocating saw and on bottom I broke the bolts and blew them out with an air hammer and round chisel on the air hammer.....a grade 5 replacement bolt cost me 4.29 at the local hardware store and .79 for the nut! the rears were wrong so I mailed them back to Summit, my new ones should be here within the week
Old Feb 19, 2010 | 12:50 PM
blackedoutV6's Avatar
....theres a nut on the piston part of the shock that youre supposed to put a wrench on to keep it from spinning
Old Feb 20, 2010 | 05:35 PM
these were aftermarket shocks.......I didn't see a nut.....I looked, I promise
Old Feb 24, 2010 | 05:16 AM
Murph2006's Avatar
at 164,716 miles, would it be a good idea to change shocks? dont really know a whole lot about shocks, but i do know that my truck doesnt ride near as good as it did when i bought it 3 years ago with 116000 and my front passenger side makes a loud pop when i hid a hard bump or pothole.
Old Feb 24, 2010 | 09:59 AM
primerib's Avatar
Air ratchet and vice grips makes it easy. I'll be doing this when spring comes and replace my crappy (too stiff) rs5000's with some rs9000xl's.
Old Feb 25, 2010 | 12:40 AM
you can always loosen the bed bolts and put a 2" block of wood between the bed and frame for added clearance.
Or take the bed all the way off and its a breeze
Old Feb 25, 2010 | 12:41 AM
probably need ball joints too, and yes the shocks definitely need to be replaced
Old Feb 25, 2010 | 04:10 AM
Murph2006's Avatar
Thanks patman ill get on that tomorrow!
Old Feb 25, 2010 | 09:39 AM
OUMX117's Avatar
Or there's always the "torch the top nut off" method. this way works very well and is quite fast, but you gotta make sure there is nothing around that can catch fire.
