'98 Wheel conversion
Has anyone ever successfully found a combination to convert the Ford 10.25 axle differential to either a 6 lug pattern or an 8 lug pattern to get away from these silly 7 lug wheel patterns?
Bob
Venom65
Bob
Venom65
http://www.motorsport-tech.com/wheel_adapters.html
Go there and they can build you a set of adapters to whatever bolt pattern you like. Probably not going to be cheap but it will be cheaper than whatever else you had in mind. Probably.
