You can program a PATS key using only one key!
Old Jul 27, 2016 | 03:57 PM
TheBigKahunaNC's Avatar
So, on my 2008, I only have one key. Can I or can I not, program a 2nd key?
Old Jul 27, 2016 | 08:31 PM
projectSHO89's Avatar
No, you cannot do so without an appropriate scan tool (or equal).
Old Jul 28, 2016 | 12:50 PM
Concurred
Old Aug 5, 2016 | 10:08 AM
Been quoted anything from $75 to 200 to cut/program a transponder key. A couple of places absolutely won't touch cutting my own key blank. Says it breaks their bits.....
Old Aug 5, 2016 | 01:45 PM
Have you tried Walmart?
Old Aug 5, 2016 | 02:37 PM
I do not believe that the WalMarts around here program transponder keys. They can barey cut a house key.
Found a place that did it for about $40. I already had a key that I purchased online. One problem I ran into was most places want you to buy their key. I was told twice that "we do not or do not like to cut "aftermarket" keys". But they will sell you a basic plain transponder key for $49 or more. I can buy them online for less than $15. I bought the one with the remote door locks built in for about $12! So this place went on about how they couldn't guarantee it would work, etc. It worked fine. I programmed the door locks in a few seconds and was done.
Old Aug 5, 2016 | 06:29 PM
The Walmart here has the computerized cutting machines that will cut and clone a transponder key. They aren't that expensive, I think it's about 50 bucks including the blank.
Old Mar 23, 2017 | 10:36 AM
ops's Avatar
ops
2010 F 150 replaced PCM and truck wont start. Anti Theft still flashing, someone told me I have to reprogram my keys to the new PCM. Anyone have any advice on how to do this or is it even possible
Old Mar 23, 2017 | 12:45 PM
It is MANDATORY that the PATS system be reprogrammed when a PCM is replaced on any F150 starting in 1999.
Please read the WHOLE thread.
Old Mar 23, 2017 | 01:18 PM
ops's Avatar
ops
Is this a dealer only fix
Old Mar 23, 2017 | 02:29 PM
Dealer or a shop that has the right equipment.
Old Aug 22, 2021 | 09:23 PM
nbrownell's Avatar
Originally Posted by phil6608
If you have a hand held tuner for your truck,,I know a guy that can email you a tune that will disable the PATS altogether.
Phil
can this tune be used through an elm327?
