fuel pump replace on 2001 f150 supercrew
I learned the hard way the pump on supercrew is under the back seat. I took the bed off, but the pump is not under there. The bed isn't hard to get off and would work on anything but the supercrew.
Well it finally warmed up enough to change the pump. I used a comealong hooked to the frame to lower the front and a floor jack on back of tank. The hardest part of getting the tank down was getting the gas lines unhooked. I could only get one hand in the small space it's hard to use the little tool with one hand. After I got the gas lines unhooked it went pretty easy only took about 2 hours.
