F-150 screensaver for Macintosh?
Old Jan 2, 2010 | 05:11 PM
chiaronate's Avatar
Hey does anyone know where I can find an F-150 screensaver for Macintosh OSX? I searched on here and on the web and I found this many "0".
Old Jan 2, 2010 | 05:56 PM
Smokin Lariat's Avatar
Why not make your own. It's simple.
1) Just create a new folder on your desktop, in your documents, file, in iPhoto - whereever. Load up your own pics of your own F150 or faves from some other source.
2)Go into System Preferences - Desktop and Screen saver. Select Screen saver. There you'll see a pull down list of available files - most supplied by Mac.
3)Use the "Choose Folder: to browse to the file you created earlier - mine is called 'truck pics."
4)Select your folder of pics and it will move to your screen saver menu.
5) Then simply set the parameters for how soon to stsrt, how quickly to fade , etc and you'll have a nice F150 slide show screen saver. Use the 'test' button to check it out - make adjustments to your taste.
6) You can always then go back and add/delete photos fo your choice.
Enjoy
Old Jan 2, 2010 | 07:33 PM
chiaronate's Avatar
Wow that's cool I just did that and it turned out nice, thanks.
Old Jan 2, 2010 | 08:05 PM
Glad to help. Now you can start to play with the options of zooming in and out, crossfade or keeping photos centered, etc to build it to your taste. You can also select show in random order or deselect that and you can then build the order you want the photos to appear in --- lots of fun to stylize your own.
