HELP! 2000 4x4 Front hub. I can't get it off!
I've pulled all the bolts and it's ready to go. The axle shaft moves freely in the hub. I've beat it with hammers. I've tried a chisel and air hammer to get in between the hub and the spindle (if that's what it's called). All to no avail. It's dark now so it'll have to wait until tomorrow it's soaking in PB Blast for the night. Any ideas on a way to pull or pop this damn hub assembly out?!
Thanks in advance!
Thanks in advance!
Not sure what exactly you need. But this how to I found a while back on how to replace the ball joints shows how to disassemble everything up front. Maybe what your looking for is in here:
http://www.ford-trucks.com/article/i...ll_Joints.html
Good luck,
- Erik
Good luck,
- Erik
you have options here.
- you can try heating the spindle if you have access to a torch, heat the spindle not the hub assembly.
If you are replacing the hub assembly you can pound the crap out of it with a BFH.
You could also remove the CV axle and pound on it from right on the back of it with a large socket and a hammer.
