Lets Trouble shoot some pinging!
Lean codes both banks.
Replaced: plugs&wires, mass air, fuel injectors, egr, fuel&air filter, fuel pressure regulator, air temp sensor, oil.
I temporarly fixed problem by unplugging air temp sensor and the vacuum line on the fuel pressure regulator with premium gas. Even with the check engine lite on this fixed the problem temporarly.
Does any one know what the static fuel pressure should be and what the wot fuel pressure should be?
Might be a bad fuel pump?
Or bad cat. ?
Or bad cat. ?
Spray ether or starting fluid on it to see if you get a raise in RPM.
X3 on checking the far back pcv elbow
Lean codes are almost always an indication of vacuum leaks. The PVC is usually the source. Maybe the thing needed tuned anyway.
Yeah the pcv hoses are good for that. I see where he was going with checking the fuel pressure but replacing injectors, egr, even plugs/ wires for lean codes? Shoot first ask questions later sounds BA but it's real hard on the wallet.
