2003 supercrew leveling kit
Old Dec 8, 2009 | 07:44 PM
texastyle69's Avatar
I have a 2003 f-150 supercrew 2wd i would like to level it out what is the cheapest price i can get it for and would it be better with spacers or with the 2 inch larger coil springs do i require more parts other than those. thank u for ur time
Old Dec 8, 2009 | 08:08 PM
thejake1989's Avatar
your two main options are 1.5" daystar leveling spacer which you can get for 40 bucks from amazon or 2" lift coils off ebay or from rough country for about 100-130 buck but they may put you alittle nose high.
the only other parts you might want to get are a set of camber bolts while you doing work down there.
Old Dec 8, 2009 | 08:09 PM
Powers150's Avatar
some people crank theyre factory torsion keys personally i bought after market torsion keys and removed my 2 inch blocks in the back and replaced them with 3 inch blocks then cranked the torsion keys till it was level
Old Dec 8, 2009 | 08:10 PM
only have torsion bars on 4x4
Old Dec 8, 2009 | 08:11 PM
alex7191's Avatar
you can get the 1.5 inch spacer for under 40 or around that. the coils are just a direct swap with your current coils. the coils will of course make it taller and you might have to lift the rear too because it will probably be taller than the front depending on how saggy your leafs are. unless you like that look. the downside to the coils is it'll make the ride a little rougher than the spacers would
Old Dec 8, 2009 | 08:12 PM
alex7191's Avatar
wow! i thought i was typing fast. all of you posted while i was typing
Old Dec 8, 2009 | 08:14 PM
champion hahaha
Old Dec 8, 2009 | 08:20 PM
Powers150's Avatar
oh really i didnt know that well i guess im wrong thanks for the correction man by the way the line x and black came out great
Old Dec 8, 2009 | 08:21 PM
np. i wish it was just as easy to crank some tbars and go haha
Old Dec 8, 2009 | 08:26 PM
I called a shop today and they told me that after the spacers i would need sum eccentric camber i believe he said to align the truck as well how true is that
Old Dec 8, 2009 | 08:31 PM
those are the camber bolts i was talking about. they are about 50 bucks online and they help with aligning the truck and worth it. they replace the bolts in the uca's
part number EIB587385K
http://www.stillen.com/product.asp?i...N01&c=SU&m=all
Old Dec 8, 2009 | 08:45 PM
Good looking out jake thanks.
Old Dec 8, 2009 | 08:57 PM
Welcome man. I had ordered that kit before I realized I had a set already and I'm running the daystar kit now.
Old Dec 8, 2009 | 09:06 PM
Where in Tx are you? Wanting to do the install yourself, or with some help?
Old Dec 8, 2009 | 09:55 PM
I just ordered the spacers and bolts online all for 90$ i called and old friend before ordering to know if he could install them and he said yes so im coverd on the installation part im just gonna have to get an aligment after that but by the way im in laredo tx and thanks for helping just found sum true new ford friends thanks alot fellas.
