2003 fog light
Old Dec 6, 2009 | 11:26 PM
03Screwon22's's Avatar
Red face 2003 fog light
Ok I have an 03 F-150 XLT that has now fog light on the lower Valance, am planning to install a new lower valance with fog lights, it looks like the one for FX4, my question is, where can I get a power source for it, my plan was tapping it to my park lights so it will light up when I turn it on, but I was afraid to burn the wires, also I was planning to install HID in them... need your guys help
Old Dec 6, 2009 | 11:56 PM
thejake1989's Avatar
i think your truck may be prewired for fogs. i know this has been the case on some trucks here specifically dirtyd88.
Old Dec 8, 2009 | 09:19 PM
Layedout02's Avatar
you could run your neg wire to a ground and run you positive to a switch inside the truck and then to your pos on your battery, thats what i did, made a little switch under the steering wheel, looks like it was made that way
Old Dec 8, 2009 | 09:47 PM
illness95's Avatar
yours should be prewired.. shouldnt it??mine wasnt but mine is a 98.. i used power from the battery ran it through a relay and to a switch inside the cab..
Old Dec 8, 2009 | 10:02 PM
I think my truck is prewired, but how will it work??? do I have to but the headlight switch that has a fog light???
Old Dec 8, 2009 | 10:13 PM
illness95's Avatar
yea your gonna need a new headlight switch..
Old Dec 8, 2009 | 10:15 PM
c_ulater's Avatar
Your truck will be prewired for it. The connectors are below the headlights. There may be some side marker wires also. I put a oem switch for fogs. But you can find a power source, use a switch and tap into the orange wire, I believe, off the light switch. Truck should have all the relays so it'll be a plug and play.
Old Dec 9, 2009 | 11:08 PM
ok CULATER, so all i have to do is buy a new switch and connect the lights?? that's all???
what is this orange wire you're refering kindly explain... thanks by the way guys...preciate everything!!!!
Old Dec 10, 2009 | 12:27 AM
c_ulater's Avatar
Yes. Plugs right in. Takes about 5 mins.
If you use a separate switch you will need to splice into the orange wire. This way you can have the fogs on whenever you want.
Old Dec 10, 2009 | 11:39 AM
sharpshooter109's Avatar
Sorry to Jack the thread but this migh be some pertinent info to your situation. I have a 98 xlt with no fog lights. I ran some walmart lights to a switch like some others who have posted here but now I want to power them with the headlight switch. The switch pulls out like i am turning the fog lights on. Does this mean I can use the current headlight switch or will I need to get a new one. I understand I might need to get a relay but illworry about that later. Sorry to thread Jack but hopefully this will help you out. And good luck to you man!
Old Dec 10, 2009 | 11:46 AM
kingfish51's Avatar
No you will need the switch. It pulls out to be able to remove the switch not to power fogs.
Old Dec 10, 2009 | 12:18 PM
^^^^x2
Old Dec 10, 2009 | 09:35 PM
ChrisT's Avatar
That's it, I gotta do this mod soon. I did see the wires when I was under the truck the other day changing the oil. How much is the OEM switch? I got a price of $120 I think for the OEM 4x4 lower valance.
Old Dec 10, 2009 | 10:32 PM
c_ulater's Avatar
I think I paid around $80 for the switch
Old Dec 11, 2009 | 09:14 AM
kingfish51's Avatar
Check with Tasca parts. Might be able to find it cheaper, or check a junkyard.
