Strange metal pinging sound and collapsed hose from vapor purge
Old Nov 26, 2009 | 12:39 PM
EricV's Avatar
Have a 99 4.2 F-150 that keeps popping up a p0174 bank 2 lean code.
In my efforts to locate the cause of said code I've found the following.
Hole in catalytic converter, collapsed hose leading from the evap purge valve (hayes manual says its vapor control valve) to intake manifold, and weird metal pinging sound.
I replaced the hose at O'Reilly's last night but even the new one looks ready to collapse (soon as I fired truck up I saw the hose crimp at the bends). Not sure whats causing this. There is some evap valve that says it needs to be 1psi. Is something going on with this?
The metal pinging sound also has me worried. It sounds almost like its underneath driver side but a little forward from directly underneath. It only makes this noise at a slight increase (and I mean slight) in rpm while in park and idling or while driving and only when I'm at a cruising speed and give it a small amount of pressure on the pedal. Almost like something is rattling with the small increase in vibration from the engine but goes away when more gas is given. Hopefully that made sense.
I plugged the hole in the converter last night and reset the code but haven't driven it to see if that was indeed the culprit.
