oil filter help
Old Nov 20, 2009 | 09:08 PM
lostyone50's Avatar
oil filter help
hey wats up guys have a 2000 f150 5.4l 4x4 supercab and the oil filter is a pain in the neck to get off can any of you guys give me tips to makin it easier tank you
Old Nov 20, 2009 | 10:08 PM
4x4wolf's Avatar
Got a 2000 5.4 myself, I had troubles getting them off too. I got a oil filter wrench to get it off, now it wasn't easy but I got the wrench in there just right and could make small turns but it eventually came off
Old Nov 21, 2009 | 12:27 AM
ridinmudddy's Avatar
there is a special kind of oil filter wrench you can buy that makes it a whollle lot easier. its like a claw lookin thing that hooks onto a ratchet. im not sure where you can buy them though i just know i got one from the shop i used to work at. makes things much easier.
Old Nov 21, 2009 | 06:06 AM
Davisio's Avatar
Bought the same thing. Claw with gears that get tighter as you turn. Not ideal, but it works. Think I picked it up off amazon for like $7 and free shipping. Certainly better than wrestling with the filter for hours doing small turns.
Old Nov 21, 2009 | 07:06 AM
JNC995's Avatar
Yea, on my first oil change, I couldn't turn it off by hand, so I had to buy a wrench, then cut about half the handle off so I could make turns up in there. Now though, I just hand tighten, so when I go to remove it, I can just spin it off by hand. Much easier.
There are kits out there that you can buy that relocate it to a much easier location to access. Few people on here have them. If they don't post up, do a search or ask about it if you want to do that, and they can help you out there.
Old Nov 21, 2009 | 09:11 AM
OhioLariat's Avatar
Not the same one I have, but the same principle:
Craftsman Universal Oil Filter Wrench, Auto-Adjustable
And oil filters should always be only hand-tightened, but if you can easily spin it off by hand months later, it may not have been tight enough, and you could be at risk for leaks. I always follow the "3/4 turn past contact" rule, and have never had a problem.
Andy
Old Nov 21, 2009 | 09:16 AM
OhioLariat's Avatar
THIS is the one that I have. It only has one review (bad) on the the Craftsman site, but it's always worked well for me.
Andy
Old Nov 21, 2009 | 09:54 AM
Red02FX4's Avatar
I have a Vise Grip just for oil filters. Works great
Old Nov 21, 2009 | 10:15 AM
Frank1960's Avatar
Harbor freight has a 4 Piece End Cap Oil Filter Wrenches Remove and install hard-to-reach oil filters.
Includes four of the most popular size filter wrenches
Each wrench permanently cast with size for quick identification
Two step flute design
3/8" and 3/4" drive
Sizes: 3-5/32'' (80 mm) x 30 flutes, 2-27/32'' (65 & 68 mm) x 14 flutes, 3'' (74 mm & 76 mm) x 15 flutes, 3-31/32'' (93 mm) x 36 flutes
for $6.99
they also have the 3 prong ones showed above for $5.99 haven't used either one but plan on getting the wrench one. last time I change oil had to cut handle part way off and make small turns
Old Nov 21, 2009 | 11:23 AM
njmike's Avatar
Ive got an 01 4.6, I bought a Oil Filter "D" wrench from auto zone. It looks like a small black cup with a bunch of little teeth on it, its made to fit directly around and on the teeth of a motorcraft oil filter, the you can attach a small 3/8 drive to it. It works great i put it on the oil filter then attach the drive give it a few turns then take it off by hand. There 6 bucks heres the link http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?displayName=OilFilterWrench& itemId=774-10&navValue=100774&parentId=1311-10&productId=153160&fromString=&itemIdentifier=153 160_0_0_&filterByKeyWord=&categoryNValue=&store=16 71&skuDisplayName=93mm.dia.oilfilter"D"capwrench&c ategoryDisplayName=OilandFluidChange&_requestid=16 6745
Old Nov 21, 2009 | 12:36 PM
JimmysotherFORD's Avatar
they make oil filter relocation kits for our trucks, you can move the filter anywhere up to 3ft away from the original position.
Old Nov 21, 2009 | 05:24 PM
Powers150's Avatar
i got an 01 5.4 and i use a piece of sandpaper to grip it and then just turn it off by hand works for me and you probably have some already
Old Nov 21, 2009 | 06:06 PM
Layedout02's Avatar
If you use a K&N oil filter they have a nut on the bottom of it, all you need is a 1in wrench to get it off, they cost a little more but it makes it easy
Old Nov 22, 2009 | 04:25 PM
4wd150's Avatar
i bought a cup type for motorcraft filters since thats all i use anyhow that uses a 3/8 drive ratchet. seems to fit in the tight area the best
Old Nov 27, 2009 | 01:05 AM
nhford's Avatar
I have an '03 XLT S-cab 4x4, 4.6L.
I cannot stand changing the oil because it truly is a ---PITA-- as everyone says.
I plan to install a remote oil filter, and found Trans Dapt kits on line.
I don't know the thread size which my filters screw onto... 3/4-16 or 22mm.
I am wondering if you can help me out with that?
I use the standard FL820S filter.
Let me know when you get a chance?
Thanks, nhford
