replace cruise control button
Old Nov 18, 2009 | 10:05 PM
Chief Mike's Avatar
I have a 1998 F-150 with cruise control. The small button mounted on the right side of the steering wheel for the cruise control broke and I need to replace it. Is this an easy fix or a pain? Can someone maybe explain how to do it? Where is the best place to get the part? Thanks.
Old Nov 18, 2009 | 11:35 PM
thejake1989's Avatar
this is from a write up i have bookmarked to swap all the buttons in the truck to blue leds and this is what the guy said to do to remove the cruise buttons. more than that i cant help since i dont have it.
"ok, the first thing you want to do is disconnect the battery and let the truck sit for a couple min, and then pull the air bag fuse. on the sides of the steering wheel there sre two little tabs, pull them off and underneith you will find two small bolts that hold the air bag cover on the steering wheel. take these bolts off and pull the cover off. unhook the wiring and carefully pull the air bag off and set aside. the buttons just pop out so unhook the wires and pull them off."
