4x4 trouble 1997 F-150
Old Nov 1, 2009 | 01:25 AM
cupper56's Avatar
I have a problem with my front hubs won't lock in. The problem started getting worse gradually. I have changed the vacuum actuator on the axle. I have also changed both vacuum solinoids on the fire wall. I have checked all vacuum connections and hoses. I'm stumped Need help!
Old Nov 1, 2009 | 07:06 AM
kingfish51's Avatar
Look for a crack on the vacuum lines. That is all it takes to stop the front diff from locking in.
Old Nov 2, 2009 | 08:52 AM
skyflyer44's Avatar
Broken Shift fork in Axel
I had the same problem, Pulled axel apart found fork plastic gone! You will need Kit # F75Z3N139KG. This was not to hard to repair.
https://www.f150online.com/forums/ot...t-working.html
Mark
Old Nov 2, 2009 | 05:27 PM
jbrew's Avatar
It's usually as kingfish posted - Most common problems and they crack between the battery box and firewall.
You can stick a vac pump on the actuator to test it, go from there if the lines are good.
Also - DO NOT connect Blue and Pink lines to actuator as Ford Service directs. They have it backwards for the 97 lol. - Not kidding.
