Truck wont start
Old Oct 18, 2009 | 07:07 PM
97f1fifty's Avatar
Truck wont start
Ok so the other day leaving work my truck wouldnt turn over for any thing. We tried to jump start it still didnt work. I have replaced the battery and starter so far and still wont turn over..just kinda has a click when I turn the key. I have checked my fuses none of them are blown..All my gauges and everything works excepts the radio..and when I take out the fuse in the #15 location inside the cab the raido will then work until I put the fuse back in and turn the key on...I have no idea what can be wrong with the truck..Please help if you have ANY idea! I need to get this truck running so I dont have to drive my mustang to work every day
Old Oct 18, 2009 | 07:13 PM
jethat's Avatar
Short the small post to the big post on the firewall starter relay if the starter engages replace the relay. If it doesn't it could be connections or a bad ignition switch(very unlikely)
Old Oct 18, 2009 | 07:22 PM
97f1fifty's Avatar
My starter relay is on my starter, I couldnt find one on the firewall. But I did do that before and replaced the relay and still wouldnt work...But the truck will fire when I ground it out that way.
Old Oct 18, 2009 | 07:47 PM
ford norseman's Avatar
For 97-00 F150, hope this helps. From Alldata tsb 01-21-8:
ISSUE
Some vehicles may exhibit a no crank, no start condition. This may be caused by corrosion of the starter cable B+ terminal at the starter solenoid due to a reaction between dissimilar metals (steel nut used to attach the battery cable to a brass stud on the starter).
ACTION
Whenever the starter or harness is replaced, the new brass/tin plated nut (W706414-S413) replaces the old service steel nut. Follow the appropriate model year Workshop Manual for harness and starter replacement procedures.
NOTE IF CORROSION HAS DAMAGED THE STARTER CABLE END (CRACKED, ERODED METAL), THE APPROVED PROCEDURE IS TO REPLACE THE HARNESS. DO NOT ATTEMPT TO REPLACE THE STARTER CABLE EYELET.
Old Oct 18, 2009 | 08:38 PM
jethat's Avatar
Its behind the battery and yes you do have one. under the plastic box..
Old Oct 19, 2009 | 12:38 AM
97f1fifty's Avatar
Alright thanks! When I went to buy a new one they told me I would either have it on just the starter its self or on the firewall..So I wasnt sure. Ill check that and hope to God it fixes it...
Old Oct 19, 2009 | 06:27 AM
Have you had the cruise control recall done? I dunno about your 99, but fuse #15 in my 03 protects the stoplight switch, cruise, GEM, and brake shift interlock.
Old Oct 19, 2009 | 01:22 PM
97f1fifty's Avatar
Yes that what the fuse protects on mine also. But Im not sure if it has been done or not? On my previous truck it wasnt done when I bought it and they sent me a letter saying it needed to be done once the title was transfered into my name but I havent gotten a letter from Ford notifying me for this truck?
Old Oct 19, 2009 | 01:56 PM
1clean42's Avatar
To check your cruise, go up to the dealer and ask them to run a vin check to see i the recall was done. It's free, so why not?
edit: sorry lol, I guess you can't get it up there if you can't start it
Old Oct 19, 2009 | 02:20 PM
fordification's Avatar
Alarm system with starter disable? My brother had a problem with his jump starting when the alarm was on. Just had to hit the key fob unlock.
Old Oct 19, 2009 | 03:08 PM
97f1fifty's Avatar
Ok so I just went and bout a starter relay for the firewall...truck fired right up..I feel like an idiot now but the guy at another auto parts store said I only have one..anyways that fixed the problem...But now my truck has a new battery, new starter and 2 new starter relays....a 10$ project ended up being a 250$ project because of that guy saying I only had one. But oh well atleast now I know all that stuff shouldnt go out on me!
Old Oct 19, 2009 | 04:07 PM
jethat's Avatar
Sounds like you got advice from a chevy guy. Fords have a cylinoid on the starter and a relay om the fire wall. My 71 Mach I has ome and so does my 99 truck. I've done the same thing MORE then once. Now I have it locked in my head.. the starter IS NOT the problem.
Old Oct 20, 2009 | 03:44 AM
Put your VIN in here:
http://www.ford.com/owner-services/c...ll-information
Old Oct 22, 2009 | 06:05 AM
97f1fifty's Avatar
jethat..Now Ill be aware of that next time! But atleast ive got a new starter too lol.
glc. Thanks Ill make sure I check that out!
Old Jul 3, 2010 | 03:53 AM
rockercar's Avatar
Originally Posted by glc
Have you had the cruise control recall done? I dunno about your 99, but fuse #15 in my 03 protects the stop light switch, cruise, GEM, and brake shift interlock.
Well, I've been chasing the same problem now. I put 13" bars on, installed all new cables and the front brake does activate the stop lights.
