First maintenance for my 01 F-150
Old Sep 25, 2009 | 08:25 PM
denisbaldwin's Avatar
I just bought a house and thus the wife made me get a truck
It's a 2001 F-150 with 80k on it. Aside from typical body scratches, the truck is in really good condition.
Since I just got it, I want to do the maintenance to make sure it runs tip-top. What should be done in what order? Anything in particular I should look for or do right away?
I figure air filter, plugs, wires, fuel filter, etc.etc are a good place to start, but I'm looking for any specific suggestions.
Denis
Old Sep 25, 2009 | 08:54 PM
If you change the plugs, use only Motorcraft plugs, do NOT use antiseize, torque them to 28 ft/lb, and you don't have plug wires, you have coil-on-plug. Use dielectric grease in the COP boots, but try not to get any on the springs that make contact with the plug. Factory plugs are advertised as being good for 100k. COPs will let you know when they need to be changed, it will start to miss and/or run rough under light throttle right after it shifts into overdrive.
Air filter, fuel filter (again, Motorcraft), oil and filter (5W20 Motorcraft and a Motorcraft filter, available at Walmart), and go get the transmission fluid changed with an exchange machine. If yours is an early enough 01, it may still have a torque converter drain plug, if it does, you can do your own complete fluid change. Use only Mercon V fluid.
When you get around 100k, I'd change the differential lube and transfer case lube (if 4wd). Rear axle takes full synthetic 75W140, add friction modifier if limited slip, front axle takes 75W90 or 80W90, and transfer case takes ATF.
Old Sep 26, 2009 | 10:48 AM
F150man21's Avatar
exactly, especially the motorcraft plugs. it'll run like hell if you dont use them... trust me
Old Sep 26, 2009 | 11:09 AM
str8t six's Avatar
Congrats on the new truck!
Old Sep 27, 2009 | 12:26 PM
TidePride50's Avatar
How do you change the fuel filter? I just got a 01 with 160,000 on it and most likely it needs to be changed.
Old Sep 27, 2009 | 12:29 PM
F150NJ's Avatar
Congrats on the new truck.
How does the coolant look? Are the brake lines badly rusted?
Old Sep 28, 2009 | 12:45 AM
Tide:
https://www.f150online.com/tech/fuelfilter.html
