need help with 2000 f150 4X4
Old Sep 22, 2009 | 12:54 PM
azfred's Avatar
hello
my truck now has 202,000 on it with a new jaspers motor at 167,000. I started having an issue this weekend that I cant seem to figure out. the truck will start running a little rough, feels like its lurching some, I step on the gas and get the rpms up and it goes a way, does it at idle and just crusing down the freeway. I changed the fuel filter , didnt help. I am going to put a fuel pressure guage on it and try to run a diagnostic with a freinds computer but i am not getting any lights on the dash. if it was the fuel pump wouldnt I get a code, and since there is no code that eliminates maf sensor and coils and plugs , correct? Im stumped, any help would be appriciated
Fred
Old Sep 22, 2009 | 01:26 PM
It would not hurt to clean the MAF, IAC, and throttle body. Is this a 4.6 or 5.4, and does it have COP's or coil packs and plug wires? Do you know what brand of spark plugs are in there?
Old Sep 22, 2009 | 02:32 PM
blackbeast_FX4's Avatar
check you coils plugs and wires my dads truck was doing the same thing and its a 4.2 v6 2000 model it was carbon on the plugs if your not throwing codes its nothing to major just annoying as he** let me know what you find out bro
Old Sep 22, 2009 | 02:41 PM
logically it would seem correct on the plugs throwing codes but unfortunately it doesnt always work that way i launched a plug out of the head and completely shattered a coil pack and never got a code one ran rough as he** and sounded like a stock car but still no code easy fix though so no biggie oh its a 2002 screw 5.4
Old Sep 22, 2009 | 03:18 PM
azfred's Avatar
cop, 5.4. Im leaning towards the fuel system, since the problem goes away as the rpms come up and its intermitent. I am going to look at the regulator and fuel pressure tonight. I plugged it when I drove to lunch and watched alot of data, the the cyliders were all firing ok, but I couldnt read the fuel pressure through the obd 2, so tonight I will put a guage on it
Old Sep 24, 2009 | 12:12 PM
azfred's Avatar
wnet through all the fuel system and all was normal, after 5 days of running bad intermitantly it finaly threw a code, cyl 1 misfire, pisses me off that it took so long
