4.6..is it worth it?
The 5.4L has more peak torque, but also it hit peak lower, 2500rpm vs. 3400rpm. So under 3000rpm, the F-150 has significantly more torque than the 4.6L, more than the peak numbers suggest. They are from the same engine design with the 5.4L having a longer stroke. The 6.8L V10 is the same (design, bore, stroke) as the 5.4L +2cyl. Edmunds/Kbb suggest the 5.4L adds about $300 over the 4.6L to our trucks.
I had read from different stat websites that the 4.6 is good for building up the total #'s as in HP, Torque @ low rpms, etc.. Since I'm new here, I think you gentlemen would know and where would you start at so the add on won't be a waste before adding the next part(s).
that's right...I knew it was a gasket, but couldn't remember which one lol.
