HELP.. hazard/signal lights won't work.
Old Sep 2, 2009 | 10:34 AM
F150.919's Avatar
anyone experience this? at first,when my hazard is on,all of a sudden it went off.. then after a few mins. it went on again.. but this time, it totally won't work..
what should i check? relays? flasher?
where is this located..?
btw,my truck is an 98 v6 flareside..
thanks in advance guys..
Old Jan 2, 2010 | 01:12 AM
Ace_boy2099's Avatar
do your turn signals work like normal and just the hazards not work right? if so Did you find an answer to the problem? I have the same thing and would like to know if there is a cheap fix I can do.
Old Jan 2, 2010 | 01:17 AM
thejake1989's Avatar
aceboy do both your hazards and your turn signals not work correctly? have you checked all your fuses? do you have working parking lights?
i helped out a guy local with an issue like this so just let me know whats wrong and ill see what i can do to help out
Old Jan 2, 2010 | 01:52 AM
Turn signals work just fine. Try to put the Hazards on and they flash once and quit out, turn off and back on and they do the same thing.
Old Jan 2, 2010 | 02:35 AM
TIDOSFX4's Avatar
Sounds like your flasher relay.
Old Jan 2, 2010 | 03:20 AM
is that one of the relays in one of the fuse boxes or is that in a seperate location somewhere? Just so i know where to look.
Old Jan 2, 2010 | 06:01 AM
TIDOSFX4's Avatar
Usually its on its own under the steering column area. Never had to replace it on my truck but on my mustang that was the issue and thats where it was.
Old Jan 2, 2010 | 11:53 PM
yea id say try swapping the relay but on our trucks im pretty sure that the one relay controls both the hazards and the turn signals so since one works it might not be that.
its under the dash above the space between the brake and gas pedals. your gonna have to feel around there and find it then its got a cover that is taped down. after you get the cover off the relay is the back on closest to the fire wall. make sure you keep track of which way it was in there. get a new one at autozone for 15 bucks and see if that works.
also it might be a short with the switch.
