Help with cel please!
Old Aug 27, 2009 | 10:47 AM
cas95cobra's Avatar
I just got a 2003 f150 with a 5.4 a few weeks ago. After reading alot of helpful posts on this forum I have fixed codes P0171 and P0174 that were causing the cel, problem was the pcv tube was cracked causing a vacuum leak. Now a week later cel comes back on, I pull codes and they are P0172 and P0175 now. So i cleaned the maf again, tested fuel pressure, changed fuel filter and checked for vacuum leaks again, nothing worked. The truck does not have any drivability issues, but i am due for inspection in oct and need this light off. If anyone could give me causes of this codes it would be helpful. I tried searching and I adressed the answers i got through that, but cel stays on. any tips? thanks
Old Aug 27, 2009 | 11:05 AM
97BlueXLT's Avatar
based on
http://autorepair.about.com/library/...bl406a-lib.htm
171 and 174 together indicate together indicate a lean condition
172 and 175 together indicate a rich condition
did you reset your computer after fixing the vaccuum leak - or just clear the codes? now that the vaccuum leak is fixed, is it still trying to overcome the lean condition that is no longer there?
Old Aug 27, 2009 | 11:25 AM
cas95cobra's Avatar
I disconected the battery for about an hour, is that how to reset computer? Could the maf be bad?
