03 frame 95 cab could it be done?
Old Aug 19, 2009 | 04:54 AM
mike805ford's Avatar
hows it going everyone? I'm sure i asked this question once before and never fallowed up on it because the guy i was getting a 02 frame from ended up pulling out of the deal and sold it to someone else. I like the a-arm design over the i-beams and I'm looking in to building a pre-runner and i was wondering if its possible to put a early 90's cab on a 2000ish frame? this frame inst a sure thing tho but this time i would like to know if it can be done like do the early 90's body mounts bolt up to the 2000ish frames? could anyone help me on this i would like to know what I'm getting myself in to before i got out and get everything because if its going to be tuff i might just change my mind
Mike
Old Aug 19, 2009 | 06:23 AM
D.lee00150's Avatar
Change your mind!!! I think your looking at alot of work to be done correctly and safely. Save your pennies and hope Ford will build a Pre Runner out of the Raptor. (Dont hold your breath)
Old Aug 19, 2009 | 06:48 AM
Veteran: Army
if your building a pre-runner why are you trying to use the stock suspension??????
wound't it be safer and stronger to build arms onto your '95 frame that way you don't have the title issues either
Old Aug 19, 2009 | 03:35 PM
all very good points guys thanks. well i wanted to get a H and M long travel a-arm kits for it and it would give the truck 17in of travel in the front. after reading your posts i think I'm going to think of something else to build and yeah the raptor is a really nice truck but i don't have 40k plus for a truck i was thinking 15k including the truck seeing how i was planing on doing all the work. thanks for the advice guys but now i really have to think and see what i want to build.
Mike
Old Aug 19, 2009 | 04:00 PM
Veteran: Army
worse case why not put the newer suspension on your older frame???
Old Aug 19, 2009 | 08:58 PM
that could work the truck is going to be green sticker anyways its just going to be a toy.
Old Aug 20, 2009 | 07:59 PM
I would just build a custom frame, the 97-03 frames arent that strong, and really arent setup for jumping
Old Aug 20, 2009 | 08:15 PM
but just so you know anything is possible. I have a buddy that has a 1963 F100 (unibody) body on his 2000 V6 frame. he shortened the wheelbase by 16"
As long as you know how to measure, cut, and weld correctly you can knock it out
Old Aug 20, 2009 | 08:35 PM
4.2trimble's Avatar
My next project is putting a 97-03 Screw cab and bed on my regular cab short bed frame. bed will be shortened or totally changed...
Old Aug 20, 2009 | 08:46 PM
screws are only 01-03
Old Aug 24, 2009 | 11:08 PM
sorry about that guys been busy with school haven't had time to check up on the forms but yeah this is true anything is possible i just have to really go over it and see if its going to be worth it and thanks again guys but I'm going to have to give this a lot of though on what i want to build.
Old Aug 29, 2009 | 02:29 PM
Wouldn't that be called an.............Expedition?
