The old spare tire!
The old spare tire!
99 4.6L 2wd
I have never lowered my spare tire, went to lower it for the first time, I used the crank bar under the hood , it cranked about a 1/4 inch down, just enough for the tire to loosen up a little, but thats it. Wont come down at all!
Any ideas?
Any ideas?
BTW- Those cables are extremely long. When my trucks 3' in the air, I can thro 3 of my tires on that cable and crank them up - to get them out of the way if the tires are off the truck.
When you get it loosened up - blow the housing out with compressed air.
Go up and down with it a few times or put a little more weight on the spare. Pull the valve stem if you have to, that will give you more room to work it free. K-Mac has a good idea to.
Good Luck
I use the spare when I rotate my tires at home. Even though it is removed maybe once a year, it's pretty cruddy with mud and sand. I can't imagine what it would be like after 10 years. You may get lucky and blast out the crud with just water and a hose-end nozzle.
You may want to replace the tire after 10 years anyway. The rubber is getting old and brittle.
What r u
? You might wanna wait until that hole between your ears grows in
In other words, - Is it just me,-I don't get it. ?
________________________
Typed "Spare Tire" in the search bar and -
https://www.f150online.com/forums/19...der-truck.html
NOT ME - click the link
It's normally found in grocery stores... next to the Jiff and Skippy. I prefer the chunky but, it's all a personal preference.
