igniton problem 03 5.4
im new to the forum so i dont know exactly were to post this, but i have done some searching and havent been able to come up with anything on it, my friend has an 03 f-150 4x4 with the 5.4 engine, its got a missfire cylinder g seondary he has replaced the coil a couple times and it keeps coming back, but it also has o2 sensor codes...but i would figure the o2 would interfere with more than one if it were o2 at fault
so my question/s is can the o2 sensor make it miss
is there a way to make the igniton a whole lot easyer to deal with coil pack wise?? i know on some cars you can swap out for simpler setups just by doing some wiring....i just want to know if there is a write up on it somewere??? thanks any help is greatly appriciated
put a new plug in and see what happens. i had a misfire on cylinder 1 awhile back, switched the COPs between 1 and 2, it stayed on 1. so i went ahead and changed the plug and COP and it fixed it.
i have read that also if there not motorcraft plugs that can cause a premature miss, there autolights that are in it right now...thats what ive gained... and i belive it was to rich but i can remember for definate
