Window Motor
Old Jun 30, 2009 | 09:26 AM
Hahny13's Avatar
Window Motor
Does anyone know the process of removing the drivers sidewindow motor out of a 97 I'm goin to pick on up at the jyard today and trying to see how hard it will be before wasting time when I get there .
Old Jun 30, 2009 | 11:40 AM
Hahny13's Avatar
Update
ok so I just went out and checked out how to take it out doesnt look too difficult other that having to drill out rivets and take off appropriate linkages so on.. So i decided before I did all that I would check to see if there could be any power issues. I press the switch down and it activates the relay, I pulled the relay and tried another seems to work fine checked wiring at door at the motor put a light tester on the red and yellow wires from switch pressing down nothing pressing up it Lights up......?? does this sound right?
Could this be my problem? I figured that because I activated the relay that it was fine but im not getting the tester to light up ?
I cleaned the switch by taking it apart as suggested per another thread still same situation.
Is there anything else I should be checking or am I gonna need to tread through replacing the motor?
Thanks for the Help!
