Starter???
I think they r both called relays, not sure.
This we did is the ignition switch and its up behind the colum. It didnt fix my damn problem tho! The other relay is on the firewall it is considered the solenoid relay (i guess i sure hear alot of mixed *&^$ in this state) so I am changing that next.
But really to tell ya the truth, I just wonder if when these guys are putting the starter up and on if they are lining it up right on the flywheel. Dont get me wrong with the way this has acted over the years these things probably need to be done. But with what its doing now with frieing out of starters the minute you put them on.?? It grinds bad like the solenoid wont stop engaging until it fries the starter. Wouldnt that mean its not lined up right?
There's one more of those relays after the ignition. Starter Interrupt Relay lol, - I'm serious tho, not sure where yours is, exactly. - They changed the wiring around quite a bit after 98.
