Cup holder spring broke
The other day I pushed in on the cup holder thats located in the dash on the lower passenger side in the center. But instead of popping open it just stayed pushed in all the way. I got it pulled out and looked around inside there and noticed theres a decent size metal strip/spring that pushes it out when compressed and it had fallen out and there were two broke off small black tab looking things still inside this metal thing. How do I go about fixing this??
If you've never used a riverter, it is pretty easy. I got one for $10 at harbor freight that came with rivets.
http://www.harborfreight.com/cpi/cta...emnumber=40690
Thanks for the quick reply thats exactly what I was looking for. I already have a rivet gun/rivets so I just got done taking the ashtray assembly out and took it down to the shop and put in some new rivets and reinstalled everything and it works as good as new!
Well, now with rivets it should last as long as you have the truck.
Yea I got to looking at how it was held on and it was a pretty poor design from the factory, but like you said shouldnt have to ever worry about that again.
*When you look with a flashlight, you will see two things that look like tabs in the slot. Its the inner pair that matters. The outer pair is a red herring to make you swear.
Just examine it carfully with a flashlight and you'll see what I mean.
). Any one else have these tabs break off?
I paid for a new one after my spring came off from the plastic melted rivets. The new one only lasted 3 weeks, then I did exactly what was described above drilled 2 holes and used pop rivets and secured it in place. I haven't had another problem since. I have an extra assembly if anyone needs one (minus the spring). Great posting and instructions to correct a weak factory design.
Shawn
Shawn
