Run factory fogs without headlights??
Old Jun 16, 2009 | 07:53 PM
Powers150's Avatar
i was wondering if anyone knew a way to get factory fog lights on an 01 f150 to be on without the headlights on thanks alot
Old Jun 16, 2009 | 08:32 PM
dirtyd88's Avatar
Either wire them to a separate switch, or throw in some kind of relay bypass.That's how mine are. Of course I didn't have fogs to begin with....
Old Jun 17, 2009 | 12:53 AM
RAM AIR's Avatar
Here ya go! I know it say's 97. But, I would think they're pretty much all the same up to the 03's.
http://www.geocities.com/tedoca/headlight.html
Old Jun 17, 2009 | 01:27 AM
EBXGSXR's Avatar
that's the link i used for my truck. i am probably going to try it on my lightning within the next week since im on vacation.
Old Jun 17, 2009 | 08:43 AM
JD790's Avatar
Followed that same link/procedure on my '01. Works like a charm!
Old Jun 17, 2009 | 06:47 PM
Before you do it, you need to see if that's legal in your state.
Old Jun 17, 2009 | 08:37 PM
Powers150's Avatar
thanks for the help guys im deffintly gonna try this out tomorrow ill let you know how i make out
Old Jun 21, 2009 | 12:37 PM
Powers150's Avatar
on my 01 i got it so the switch will pull up on the parking lights however in the link it has 3 plugs mine only has two plugs i located the brom wire but im not sure as far as the white and black wire anybody know if there is a way to do it with the two plug switch ??
Old Jun 21, 2009 | 04:11 PM
RAM AIR's Avatar
Still look for the white wire w/the black stripe. An splice into it! That wire should still be their. Regardless of plugs.
Old Jun 21, 2009 | 09:05 PM
Powers150's Avatar
You were right even though there are two plugs on my switch its basically the same concept trim the inside switch and connect the brown and black/white wire thanks alot worked out great
Old Jun 22, 2009 | 02:15 PM
RAM AIR's Avatar
Awesome! Glad it worked out for ya!
