Radiator fluid
Use ONLY gold color coolant in Ford products. Zerex G-05 coolant is available at Napa auto stores for about $13 gal.
http://www.valvoline.com/products/co.../antifreeze/42
This is another reason to go to the oil change shop and let them worry about it. Once you have a flush done at the oil change shop you wont do it yourself again
Their are a few companies that make the ford gold/yellow. Unless you complatly flush out your system stick with whatever color you have. I would also remcomend that if you take it some where don't go to a quick lube place but an acctual shop where they have more serius techs not just some kids trying to make it through life.
