Gearing Opinions
Old Jun 1, 2009 | 10:30 PM
cowboyjohn's Avatar
Gearing Opinions
Doing some upgrades on my 98 4.6L F150 XLT and was wondering peoples opinions on gearing. I'll be adding the RCD 5" and going up to 35's. I do tow a horse trailer from time to time, not a ton of off road driving, but enough for the tires and lift. From what I've been reading up on I'm thinking of going to a 4:10 ratio. Any one have any suggestions or thoughts on proper gearing? Your opinions are appreciated.
Old Jun 1, 2009 | 10:33 PM
MOford21's Avatar
What do you have now?
4.10s with 35s would probably be around stock.. But since you said you tow a horse trailer sometimes- get 4.56s.
Old Jun 1, 2009 | 11:12 PM
NoLongerJeepin's Avatar
x2 on 4.56's, 4.10's would work well if you were sticking with stock tire size, but since you're going to 35's, I would go with 4.56's
Old Jun 2, 2009 | 01:19 AM
4.2trimble's Avatar
4.56 or 4.88's
if you plan to go any bigger than go 4.88's
Old Jun 2, 2009 | 05:12 AM
kaboom10's Avatar
I tried 4.56s and changed to 4.88s and still have the stock size tires. I had a TruTrac carrier installed with the gears. You gotta get that setup n the rear. Fronts are stock carrier with gear change. I've yet to find snow deep enuff to slow me down.
Old Jun 2, 2009 | 07:48 AM
primerib's Avatar
I agree with the above as well......4:10's would work well with 33" and lower, but anything above that go with 4:56's. I'm sure Kaboom has no problem smoking stock tires on 4:88's......must be a city bomber for sure?
Old Jun 2, 2009 | 09:29 AM
wandell's Avatar
I'd go with 4.56's at least.
Old Jun 2, 2009 | 09:58 AM
kaboom10's Avatar
Between the tuning and the gearing the tires are wearing out faster than expected. It does not like wet/damp/snowy pavement. There's a tune made for winter only. 2nd gear starts are needed at times. Feels like there's a load in the bed then.
Old Jun 5, 2009 | 03:49 PM
WarrenH.'s Avatar
I put a 6" fabtech running 35"s, then went to 4.56 gears, it helped, a little... If I could do it over, 4.88's would definatley be my choice. Especially if you're hauling ANYTHING. The 4.56 made it drive exactly like it was when I bought it bone stock. I'm mostly all empty highway miles now, except during hunting seasons, when I load it down with corn, feeders, dogs, etc. The 4.6 is not a great towing engine at all even for that. According to my edge evo on level two I'm holding a steady mpg between 15.5 and 16 unloaded. Every now and then I'll hit 17 mpg with the wind to my back, but loaded that easily drops to 13-14. I've also got a Spectre cold air intake and no muffler at the present. I'm fixing to delete the rear cats and see if that may up the mpg's a little bit more. 4.88, yup definatley...
