A problem when in reverse...pls help?
Old May 26, 2009 | 02:31 PM
MassMarc's Avatar
Question A problem when in reverse...pls help?
Hello,
When backing-up my 2000 F-150 XLT 5.4 Off Road, the truck makes a horrendous squeeking sound. This does not happen while driving forward, it only occurs in reverse.
Someone said it could be the u-joint? Any thoughts?
Thanks,
Marc-
Old Jun 18, 2009 | 01:56 AM
Redfuryford's Avatar
Registered User
It's most likely your u-joints because i had a buddy that had the same problem after a while you will notice the sound when you down shift to after a quick fix the sound was gone
