Multiple electronics mounting in my Scab
Old Apr 27, 2009 | 09:53 PM
BigKev's Avatar
Ok so I got a few things I'm gonna be putting in my truck. I have a Uniden BCT15 scanner, a Cobra 29 LTD, and another SVP SS700 siren to mount somewhere. I had a Cobra 19 and an SS700 mounted under the dash before i was ripped off but the cup holder got in the way of the CB and vice-versa. Anyways I'd like to see some pictures of multiple things mounted under the dash. I have a 40/60 split seat with no flow through console, and a manual 4x4 level.
Old Apr 29, 2009 | 10:54 PM
Bluegrass's Avatar
Consider makeing a stand assembly that bolts fast to the seat mounting brackets.
On the assembly you can mount the equipment in any vertical combo.
It's easy to get at but nothing is immune to being stolen.
Put a soft cover over the whole assembly so nothing can be seen to make decisions to breakin, easy.
Antennas are a dead gve-away to what may be in the truck so you have to live with the possibility.
I run Ham radio gear and don't put it in unless I am going to use it for the drive.
Old Apr 30, 2009 | 01:15 AM
BigKev's Avatar
Yeah I've thought about that but my seats get moved back and forth alot. I guess I could just extend it far enough out to clear the seat all the way forward but that would restrict using the middle seat. Anyone used something like a laptop mount retrofitted to hold said combo? I've see The CB i imagine doesn't have to stay in all the time but the the scanner is used daily and the siren is used at unexpected times so I guess covering the setup is the way to go. Thanks for the input n this done with just one item but never several.
