Can you help me with my ABS and 4WD 4X4 problem not working?
Old Apr 4, 2009 | 01:54 AM
pleased1's Avatar
My truck is a 1999 V8 5.4L F-150 FX4 with the electric shift 4WD. I have two problems that I think that they could be related. First off my ABS light turns on solid when i shift to drive and accelerate to about 2 mph any time i drive. My other problem is my 4WD. When I turn my **** to 4WD H or L (of course going to low through neutral) the trucks front wheels will not pull at all. All the 4WD lights in my dash seem to work properly. I have been doing some reading and was wondering if both of these problems could be the result of a faulty VSS sensor. If anyone has any tests I could perform or any advice on how to fix these problems or if someone could tell me if these problems are even related, it would be greatly appreciated.
Old Apr 19, 2009 | 11:10 PM
pleased1's Avatar
I got it fixed my abs was a speed sensor on the top of the rear differential. My 4WD problem was a faulty vacuum actuator motor.
Old Apr 21, 2009 | 10:06 AM
Hunt&Fish's Avatar
Thanks for posting the solution. i always appreciate shared knowledge. Welcome to the forum.
Old Apr 22, 2009 | 09:11 PM
rubberburner's Avatar
I read ur first message and knew the 4x4 problem would be vacume realted. So dissapointed I couldn't be the one to help u
