Ac
Ac
I got an 02 lariat screw and the AC dont work all that great.. it only comes out of the defrost area (ontop by the glass). itll start working after driving around for 30minutes or so. does anyone know the problem?
TIA
TIA
Mine was doing the same thing, it would blow out of the defrost, but not vents. It started out as a small problem, it would come and go. Then it finally got to the point were it would only blow out the defrost. I checked for vacuum leaks and finally had my mech to check it out. Found out that this was happening quite a bit with the Lariats because the solenoids in Electronic Climate Control units were going bad. That is what happened to mine. Ford does not sell the solenoids, just the complete unit. Thank goodness that I had an extended warranty, it cost about $600 2 years ago
I would go ahead and check for any vacuum leaks just in case!
good luck
We checked the lines that come into the backside of the unit, inside the cab
