F150 03 - Automatic transmission - HELP
Old Mar 21, 2009 | 02:04 AM
cralx2k's Avatar
This issue happened today. I didn't get any signals of this problem before. I drove a couple miles and I noticed the automatic shift didn’t respond when I stepped on the acceleration pedal. So I stopped, turn off the car and when I started the truck again, I shifted to shift 1 and the transmission didn’t respond. I changed to Park, shift 2 and so forth and I got no response. The truck has only 56K mileage. Is Ford covering this problem during warranty? Do I need to replace the transmission? Thanks all
Old Mar 21, 2009 | 08:57 AM
Veteran: Army
did you check your shift cable??
do you have a warranty on your truck???????
Old Mar 21, 2009 | 08:59 AM
Veteran: Army
got some more questions...
how is it parked??
does park work? or are you using the parking brake?
how far did you drive it?
when is the last time the tranny fluid was changed or even checked????
what codes if any has the truck thrown?
Old Mar 21, 2009 | 11:27 AM
cralx2k's Avatar
Yes
I don't have ESP.
Old Mar 21, 2009 | 11:33 AM
cralx2k's Avatar
how is it parked??
It's parking in my garage.
The parking brake is working.
I drove about 7 miles.
The fluid level is ok. The fluid color is light red. I never changed the fluid.
I don't have a computer. but the light panel is normal.
Old Mar 22, 2009 | 04:35 PM
Veteran: Army
so what happens when you shift the selector into park??? does the truck go into park???
Old Mar 23, 2009 | 07:57 AM
cralx2k's Avatar
Yes, I'm able to shift.
