100 shot on a 2000 5.4?
I went to HRP this friday and ran a 15.7@86. Im looking for some more. I wanna go ahead and do a 100 shot. I know ill need a good tune, fuel pump, and injectors. But idk what fuel pump or what # injectors to run. Any help?
i wouldnt do nitrous on a truck that old with a stock transmission. ur gonna blow something
i just need to know what injectors and fuel pump to use
A 100 shot on a stock tune will be fine. Just be sure to be spraing only on premium. You could probably get away with it on the stock tune as well. Just be sure to run some cooler burning plugs at about .035
The stock fuel pump will flow enough fuel to run a 100 shot. The injectors get by passed with the extra fuel from your schrader valve. I wouldn't bother upgrading your fuel system unless you plan on running a lot more power in the future. If you are gung hoe on upgrading it then run 30-42lb injectors, a 255 lph fuel pump and 80-90mm MAF.
yes you will be fine. If you have an xcal just pull about 4 degrees of timing at WOT 6 degrees if you want to be on the real safe side and spray away, but a decent tune for it will be better. The zex kit is the one to get especially for these mod motors. Just don't forget the cooler burning plugs and gap them to about .035
