2003 F150 2WD Leveling question
Ok, I seem to be getting mixed signals from some of the accessory websites. On a 2WD, do I need a leveling kit or does it have a torsion bar I can adjust to level the front end of the truck? I read in a forum that 2WD's dont have torsion bars but springs.
I dont mind spending the money but dont want to if it is something I can do.
Thanks in advance for you help.
i have a daystar 1.5" coil spacer on mine. it leveled it perfectly. cost about $90 from 4wheelparts. but you can find them cheaper online
you can get the 1.5" kit and you shouldnt need camber bolts or new ucas
linky
http://www.autoanything.com/suspensi...0A2679996.aspx
linky
I would not reccomend the daystar or the trailmaster. I have the daystar kit now and its sagging about an inch more then when i installed it over a year ago. I was told that i should use a stell set of spacers instead so if i were you i would just start with them
ive had mine on for almost 2 years and havent had any problems with them sagging. they look just as good as the day i put them on
Also, are there any leveling kits for '97-'03s that bolt on top of the shock assembly like the AutoSpring for the '04-'08s?
My goal is to get a 3.5" spindle with a 1.5" coil spacer, but that most likely would require new UCAs, and I'm having a bit of trouble finding some for '97-'03s.
The 97-03 4x2's have a completely different suspension system than the 04-08's. They do not have coilover shocks so a spacer on top of the shock would do absolutely nothing.
Also, the 1.5 inch coilspring spacer wouldn't require new upper control arms. I believe you can go to 2 or 2.5 inches of lift with a spacer or lift coil without needing new longer control arms.
