How much power
Old Feb 11, 2009 | 11:09 AM
Green_Machine's Avatar
How much power
Hey guys, i am adding e-fans and underdrive pullies this weekend. How much of a gain should i get, and will i notice a difference in the throttle and get up n go of the truck?
Old Feb 11, 2009 | 11:23 AM
dirtyd88's Avatar
Yea, you definitely will notice. I think the fans add about 2-3 to the wheels (from what I have read elsewhere) and the pulleys add about the same (also read that somewhere).
I'm sure someone else will chime in with a more definite number scheme for you.
Old Feb 11, 2009 | 11:31 AM
Veteran: Army
you're pretty close there dirtyd88
Old Feb 11, 2009 | 12:03 PM
wandell's Avatar
I've always read posts saying the electric fans are a great mod.
Old Feb 11, 2009 | 12:28 PM
dd88- Thanks, yeah the guys I'm ordering everything from said I would notice a difference right away. They said I'd be looking at 10-15hp gain total...
Yeah I've heard they are a great mod also, just didn't know if i wanted to pull the trigger and have it done. But now I am getting ancy cuz I haven't done anything to much truck in a while, so i figured why not....
Old Feb 11, 2009 | 01:59 PM
dirtyd88's Avatar
The e-fans will give you noticeable MPG gains as well. I hope to have a set on my truck next summer....im undecided yet about UDP's
Old Feb 11, 2009 | 02:08 PM
I am doing udp b/c i plan on super charger within a year or two.
Yeah the guy is supposed to order them today, i just have to tell him which kind to get....
Old Feb 11, 2009 | 02:19 PM
Veteran: Army
GreenMachine do not put on the UD pulleys if you are going with a supercharger, I had mine on with grreat results and I was going turbo when I bought them but when I put the supercharger on I had to remove them...
peak gains will only be few Hp and TQ but the overall power curve will be improved with the E-fans
Old Feb 11, 2009 | 02:34 PM
So its ok to use them with a turbo? It will be awhile before I do that so even if the udp won't work with it, i can use them until then, ya know....
Old Feb 11, 2009 | 03:21 PM
Veteran: Army
yeah they will work with a turbo, and YES you can use them until you upgrade, which is exactly what I did then when you are done with the pulleys you can pass them on to another lucky individual
Old Feb 11, 2009 | 09:19 PM
Typow07's Avatar
I also herd that it makes your truck pretty quiet too... not talking about the exaust haha, is this true? id imagine it is exspecialy on a cold start
