Bumper conversion....
Old Jan 25, 2009 | 09:30 PM
LXA-03'FX4's Avatar
Im getting a body lift on my 03 fx4 and I wanted to know if the tow hooks would be out of the way enough to fit a harley davidson front end on it.
Old Jan 26, 2009 | 12:30 AM
Showya's Avatar
Nope, actually would have to grind down the ends of the frame rails to make it work. There is a clearance issue between 4x2 and 4x4 frames.
Old Jan 26, 2009 | 04:12 AM
phil6608's Avatar
The tow hooks will be in the way. Only difference is the lower valence.
I took off my tow hooks on my 03 4X4 and put a Lightning front bumper on!
Phil
Old Jan 26, 2009 | 04:30 PM
LXA-03'FX4's Avatar
so no tow hooks and it will work....hmmmmmm......is there any other valance with fogs that will work other then hd
Old Jan 26, 2009 | 06:12 PM
phil6608's Avatar
Your stock one will look good if you paint it to match or black.
Otherwise,,you'll have to find an aftermarket valence or bumper cover with holes for tow hooks.
Phil
Old Jan 26, 2009 | 09:53 PM
LXA-03'FX4's Avatar
yeah ill probably just get it ptm but im gettin a new oem valance and bumper cause both are in ruff shape.
